Activity Forums Apple Final Cut Pro Legacy Anyone seen this issue ?
  • Anyone seen this issue ?
    Posted by James Mortner on August 16, 2011 at 12:20 pm
    Hello all,
    Quite annoying issue Im having: FCP seems to beachball and lock up when any web browser is running. As soon as I close it, FCP resumes quite happily.
    Is it a memory issue ? Nothng else is open, you would think a Mac Pro with 12gb of ram could handle two programs open at once. Im running snow leopard currently.
    Any thoughts would be appreciated !
    James Mortner
    James Mortner replied 15 years, 1 month ago 2 Members · 4 Replies
  • Jerry Hofmann
    August 16, 2011 at 12:42 pm
    James, when is the last time you performed a clean install on your startup disk? If you’ve not done that in a while, it’s likely time. What you see isn’t a bug in the software or we’d all be seeing it…
    Jerry
  • James Mortner
    August 16, 2011 at 12:44 pm
    Around 6 months ago ? Strangely this started happening after the install…
    Perhaps its time to do another one 🙁
  • Jerry Hofmann
    August 16, 2011 at 12:50 pm
    Could sure be an install gone wonky… Not common, but not unheard of either. Pretty much it’s best practice to rebuild a startup disk from the ground up any time there’s an upgrade from one OS to another (aka Leopard to Snow Leopard) and any time there’s a new version of FCS (FCS 2 to FCS (2009). About the only time it’s not necessary is on a new machine installing Studio on it for the first time.
    But doing it clean does really make a difference in my experience. We do this every 6 months at the 75 edit bay school I teach, and it’s paid off in extremely stable setups. I don’t think a single user setup needs to do this as often per se, but only when things happen as described above.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • James Mortner
    August 16, 2011 at 12:57 pm
    Sounds totally plausible, thanks very much for your advice !
