Activity › Forums › Apple Final Cut Pro Legacy › Anyone see trouble with 10.4.6 and FCP ?
  • Dan Riley
    April 6, 2006 at 7:27 pm
    OH, I see on down the forum page you guys already posted that
    in general, it seems to be fine.
    Dan
  • Pierre Jasmin
    April 7, 2006 at 12:39 am
    There appears to be a bug in the updater though,
    if a plugin uses the vec lib (that would be things like Altivec optimization as we do) it goes wrong
    The fix is here:
    https://www.revisionfx.com/generalfaqsOSX104.htm
    Pierre
    RE:Vision Effects
  • Kubatko
    April 7, 2006 at 4:58 am
    yeah i found two :
    1) Magic Bullet suite wouldn’t work – but that is fixed , download the package and instal again the update
    2) no export to Compressor from the FCP as a stand alon its fine …
  • Michaelle Stikich
    April 10, 2006 at 7:21 pm
    what happens when you try to use compressor? do you get an error message or does it just not launch?
    gir
