Activity Forums Adobe After Effects Anyone know what this error message means
  • Anyone know what this error message means
    Posted by Kilbsy on May 16, 2006 at 11:35 pm
    hi.
    I am midway through a project in After Effects 7. Whenever I click on the timeline it gives an error saying.”after effects error:open gl.failed to share context color monitor depth must be 32″
    Anyone know what is going on…I cant continue with the project instead having to go to an earlier archived version which is fine at the moment.
    This has happened before though and I wonder if its something I am doing or a hardwear fault.
    Any ideas appreciated..
    Thanks…
    Kilbsy replied 20 years, 3 months ago 2 Members · 4 Replies
  • Bj Ahlen
    May 17, 2006 at 12:51 am
    Have your set your display card to use 32-bit color depth?
  • Kilbsy
    May 17, 2006 at 4:55 pm
    My display is set to 32 bit already. I can’t understand what is wrong. MAybe I will reinstall the card see if that helps.
    Anyone got any other ideas?
    Its fine in some projects. It only seems to happen when in 4 views mode sometimes on 2 views mode..
  • Bj Ahlen
    May 17, 2006 at 7:19 pm
    Before reinstalling the card, you should check for updated video drivers for it, especially with the symptom you just described.
    Mac or PC?
  • Kilbsy
    May 18, 2006 at 1:47 am
    Hi, I reinstalled the latest driver and all is well. Thanks for your reply though.
