Activity › Forums › Apple Final Cut Pro Legacy › anyone know how to do this??
Posted by Derek Nagle on June 2, 2008 at 6:16 pmi want to record the computer screen (with a program not a application)
also i have i showu program and records perfectly, but when i bring it into final cut, i have to render it and then it becomes useless.Zak Mussig replied 18 years, 3 months ago 7 Members · 6 Replies -
Steve Eisen
June 2, 2008 at 6:19 pmSnapz Pro.
Have you thought about using a video camera. You get get good results if you have an LCD display.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Michael Gossen
June 2, 2008 at 6:26 pm[derek nagle] “(with a program not a application)”
Sorry, not completely sure what you mean. There are several good applications to record screens, like Snapz Pro. I am sure others would be excited to share their experience and give recommendations with others too. If you want to edit with it, you might want to transcode your video to a more FCP friendly format. Depending on your final destination, you might just consider DV-NTSC. Use Compressor to batch transcode your media…it will take some time, but it will probably be worth it if you are editing heavily. Good luck.
Michael Gossen
Helium Digital Media -
David Roth weiss
June 2, 2008 at 6:30 pm[derek nagle] “i have i showu program and records perfectly, but when i bring it into final cut, i have to render it and then it becomes useless.”
Derek,
You need to insure that you are selecting the appropriate codec that exactly matches your timeline. I use iShowu and I am able to use the QTs it generates on te timeline without rendering before a preview.
BTW, it sounds as if you are still using FCP version 5. Am I right? Are you aware that version 6 has been optimized for realtime playback of mixed media on the timeline? What required rendering just to preview in all previous versions of the software will now play as a preview in almost every case without rendering.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Jeremy Garchow
June 2, 2008 at 6:41 pm -
Zane Barker
June 2, 2008 at 6:41 pm[derek nagle] “with a program not a application”
Those are two words for the same thing.
[derek nagle] “when i bring it into final cut, i have to render it “
Thats because your record setting do not match your timeline settings.
Check out ScreenFlow It lets you do your recording and then choose what setting you want to save the video as.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Zak Mussig
June 2, 2008 at 9:06 pmI’ll second (or third) Screenflow. I’ve played with the demo, but haven’t had a real need for the app yet. It is by far the best in class screen capture app on the Mac. Depending on what you’re doing, you may not even need to bring the capture into FCP as SF has some basic but capable editing tools.
Zak
