Activity Forums Adobe After Effects Anyone know how to cut and paste an illustrator file into psd and make it transparent?
  • Anyone know how to cut and paste an illustrator file into psd and make it transparent?
    Posted by Jennifer on May 9, 2006 at 12:58 am
    Help help help.. im trying to move a 50% transparent black graphic from illustrator into psd. Everytime I do it pastes it at 100 percent transparency and its grey. What am I doing wrong?
    Thank you!
    Andrei Firtich replied 20 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tony Bartolucci
    May 9, 2006 at 1:04 am
    Jen or Jenn,
    It seems to work for me Edit-Copy, then in ps edit- paste- then as smart object… Of course that’s only if your using CS2… but it should work the same in any ver of ps…
    Tony
  • Jennifer
    May 9, 2006 at 1:09 am
    Im working in CS and it just pastes grey when I cut and paste. Very frustrating. Thank you for your post!
    Jen : )
  • Tony Bartolucci
    May 9, 2006 at 1:17 am
    Well I believe that it is pasted gray but its at 50% transparency…Yes PS says 100%. Maybe it would be better for you to paste it as a path, then you can just change the ps opacity.
  • Jennifer
    May 9, 2006 at 1:20 am
    Good suggestion, alas, I have many layers to move into psd and moving them as a group is the only way to go right now. Wish I had CS2!
  • Chris Figat
    May 9, 2006 at 2:25 pm
    Would it be hard to make it black, cut/paste, then adjust the opacity in illustrator?
    chris
    i’m not random i’m tangent oriented
  • Heather Memmel
    May 9, 2006 at 7:22 pm
    I believe if you start in Photoshop and go File> open> navigate to your illustrator file and open it through photoshop it should preserve the transparency.
  • Andrei Firtich
    May 9, 2006 at 8:54 pm
    Try going to the Illustrator preference menu and into File handling and Clipboard, then in the Clipboard on quit uncheck AICB(no transparency support) and check PDF. This worked for me when I tried it
