Activity Forums Adobe Photoshop Anyone know how to can print these exact circle size on a letter size (8.5×11)?
  • Anyone know how to can print these exact circle size on a letter size (8.5×11)?
    Posted by Jaymes Gordon on September 16, 2020 at 8:42 pm
    Does anyone know how to can print these exact circle size on a letter size (8.5 x 11) on Photoshop CS6? I’m pretty sure there’s a settings somewhere in the printing settings, but I couldn’t find it.
    I was able to do it on Microsoft Works by pasting only one single circle there and adjust the object size. But in my case, I want 4 circles at a pattern. It seems complicated. Please help. …see photo attachment for more detail. Thanks.
    Brendon Murphy replied 5 years, 11 months ago 2 Members · 1 Reply
  • Brendon Murphy
    September 17, 2020 at 1:36 am
    Not sure what you’ve tried so far, but I have good luck saving to a photoshop pdf and printing through acrobat. Make sure you use “actual size” in the print dialogue. One issue I see in your design is that there’s no margin. Many printers cannot print all the way to the edge of the page.
    So in short:
    -Create your graphics in an 8.5″X11″ document at the exact size you would like them to print (use your rulers under the “view” menu, and guides to check everything).
    -Keep graphics at least .25″ from the edge of the document
    -Save as photoshop pdf (high quality or press quality preset should do it)
    -Print through acrobat using “actual size”
