Activity Forums Panasonic Cameras Anyone here with an HVX and a DVX? Need some help.
  • Anyone here with an HVX and a DVX? Need some help.
    Posted by Gary Hughes on June 6, 2006 at 5:59 am
    I don’t have access to an HVX-200, but I’m considering purchasing one if a bid goes through. I’m bidding on a project and intend to buy the HVX for that project, but my client wants to see the difference between the HVX-200 in HD 24P and the DVX-100 in 16:9 miniDV 24P on the same or similar footage.
    I know it’s a lot to ask, but if anyone here happens to be shooting and wouldn’t mind uploading a few seconds from each camera to me (via ftp), I’d be an extremely happy fellow shooter. I’m really hoping to see a big difference, and I’m sure there is a big difference. If I can sell them on HD, then I can afford to make the jump.
    Thanks in advance,
    Gary
    Gary Hughes replied 20 years, 3 months ago 3 Members · 3 Replies
  • Noah Kadner
    June 6, 2006 at 4:06 pm
    That’s kind of a lot to ask from a stranger but any dealer should be able to help you out- for example in L.A. and NYC AbelCine can probably get you setup with some demo footage. Also there’s a ton of HVX footage on the internet. Here for example:
    https://www.dvxuser.com/V6/forumdisplay.php?f=57
    As far as the difference between the DVX and the HVX- it’s kind of obvious just looking at the specs. If the client is not aware of why HD it superior to SD it’s going to be a tough sell any way you slice it.
    Noah
  • Mike Schrengohst
    June 6, 2006 at 4:07 pm
    I have both cameras. Don’t use the DVX anymore, (e-bay??)
    Overall you will get best results with HVX.
    I had the first DVX and never shot 16:9
    but did shoot a lot of 24p. The DVX100B
    has a 16:9 mode but you are limited to
    DV with the DVX.
    Once you work with DVCPRO HD even if it
    is for an SD project you will see a
    difference in post.
    I am urging people to consider the long-run and
    not just the next project. Check out some
    of our clips. You can download a free clip
    (more will be added in future)
    Most of the video on the site was shot with HVX.
    Mike Schrengohst
    http://www.MotionZoneHD.com
  • Gary Hughes
    June 6, 2006 at 6:02 pm
    Thanks for the links. That definitely helps. I will check with a reseller for some footage also, but more links or any other real-world footage would still be nice. I know it’s a lot to ask, but it can’t hurt to ask, none the less.
    Thanks again,
    Gary
    Gary
