Activity Forums Apple Final Cut Pro Anyone has this ‘bug’? Multiple In-Out points Event switched in Timeline?
  • Anyone has this ‘bug’? Multiple In-Out points Event switched in Timeline?
    Posted by Mathieu Ghekiere on January 25, 2013 at 12:01 pm
    I’ve had this happen a couple of times, on new rMBP’s 15″, Pegasus Raid, FCPX 10.0.7, and can’t remember it happening on 10.0.6, so I’m wondering if this is a bug introduced in 10.0.7:
    I have a one-hour clip, Prores LT in the Event. I skim trough it, put multiple in-and out points, having 2 clips in my event clip.
    I click E for append to storyline.
    It puts the 2 clips in the storyline, but the second clip first. It switches their order.
    And it does this even if I made the ranges in the correct order (first range 1 chronologically, then range 2).
    Anyone had this bug, or is this a user error? (I never had it in 10.0.6)
    Mathieu Ghekiere replied 13 years, 6 months ago 2 Members · 2 Replies
  • James Cude
    January 25, 2013 at 5:22 pm
    Yeah it’s actually by design- multiple selection ranges from an Event are edited according to descending selection order, not chronological. If you mark Ranges 1, 2, 3 on an Event clip, they will be edited into the Project 3, 2, 1, regardless of their chronological position.
    If that seems counterintuitive, I recommend sending feedback to Apple about why you think it should be the other way around: https://www.apple.com/feedback/finalcutpro.html
  • Mathieu Ghekiere
    January 26, 2013 at 10:05 am
    I sure will.
    Very tricky.
    I both made the selections in a 1,2 order, as they are also chronological in that way. Very strange that FCP X puts them as 2,1 on the timeline.
