Activity › Forums › Apple Final Cut Pro › Anyone has had a share problem like this?
  • Anyone has had a share problem like this?
    Posted by Carlo Ferraro on December 15, 2012 at 8:29 am
    Working for a year now, version .07, never had something like this.
    Rendering a video 22 min to make a Master AppleProRes (coming from same codec) that normally takes 30 min, now it arrives to 49% and sticks there with no further change. Shifted to another drive and it is the same. Turned everything down (Off) and restarted again and it persists. The only thing I have left is to uninstall and install again FCPX.
    (Does anyone know if there is a way to keep it on the HDD without having to download it again?)
    Imac 27 Quad 2.93, 8GB Ram, 1GB Graphics, FW800 external + Raid
    http://www.birdsaustralia.net
    http://www.ferrarovideos.net
    Nick Toth replied 13 years, 9 months ago 2 Members · 1 Reply
  • Nick Toth
    December 15, 2012 at 8:44 am
    Investigate all clips, transitions etc. at the point where the render stops. I have run into this a couple of times and both times there was a transition or transitions right around the point where rendering stopped that, when I removed them, the render finished with no problem. Also, you can try deleting all project render files first.
