Activity Forums Avid Media Composer Anyone had this error before?
  • Anyone had this error before?
    Posted by Bp on September 27, 2010 at 6:15 pm
    Hello All,
    I’m getting this error contintually on my system here at work and I was hoping someone could give me some insight on what the problem might be.
    First off, I’m running Media Composer 3.5.4 on a PC platform with Interplay. We’d run a newer version of Media Composer but we need to upgrade our Unity to make that happen.
    Anyway, when attempting to export a quicktime reference file for use with After Effects or Sorenson Squeeze, I keep getting this error:
    Exception: Can’t create a directory, as one of the folders in the path below has insufficient permissions: path D:\AvidMediaFiles\MXF\
    Does anyone have any insight on how to fix this?
    Brad
    Mark A. stuart replied 15 years, 11 months ago 3 Members · 2 Replies
  • Bill Stephan
    September 27, 2010 at 11:56 pm
    The Windows permissions for your folder might be set to read-only, or you might not have sufficient permission from your Windows log-in to write to the folder. Sometimes these permissions can become scrambled by themselves. You need an administrator to fix the permissions in Windows control panel.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Mark A. stuart
    October 5, 2010 at 3:35 pm
    yes, we too have had that and it was the windows permissions settings. If you’re on a multi-user system, this can only be changed by the administrator.
