Activity Forums Blackmagic Design Anyone getting “No Video Input” flashing on PCIe Decklink cards?
  • Anyone getting “No Video Input” flashing on PCIe Decklink cards?
    Posted by Peter Corbett on June 17, 2006 at 4:45 am
    I’m on my second HD Extreme PCI-e card with the same problem. When entering capture in Premiere, I get the occasional one frame flash of “No Video Input”. This occurs on two different setups. I’ve moved from a Gigabyte GA-G1975X to a certified ASUS P5WD2. The only common denominator is the RAM, Wacom and power supply. I’ve tried house sync and no sync, all analog and SDI inputs, different decks, you name it. Drivers from 5.5 to 5.6.
    It’s got me totally beat. Black Magic has looked at the first card and couldn’t find a fault. If I install a standard PCI Decklink SDI card it captures fine on both motherboards. Jeesh!!!!
    Peter Corbett
    Powerhouse Productions
    Australia
    http://www.php.com.au
    Andrew Mcleod replied 20 years, 2 months ago 7 Members · 14 Replies
  • 14 Replies
  • Manuel Deo
    June 18, 2006 at 1:04 pm
    hi Peter,
    I have the same probleme with my decklink card. It’s a HD Pro dual link, and i have no sdi video input.
    You are not the only one to have this probleme, and i don’t find an issue to this probleme.
    If you resolve your problem, i’m also interrested by the solution
    MAnuel
  • Peter Corbett
    June 18, 2006 at 1:15 pm
    Hi Manuel,
    Yes it’s incredibly frustrating. Matt and the guys tested my original card without being able to duplicate the problem and I’m really appreciative of their efforts, but it still doesn’t work, even with a new replacement card. The fact that I have the same problem in two different PCI-e computers points to the card or drivers as the source of the problem.
    At the moment I have to install a standard SDI PCI 32-bit Decklink in the computer for capturing, then replace it with the HD PCI-e for editing. I need the other Decklink in my other workstation so this install/reinstall thing can happen three or four times a day.
    I’m also using an ASUS BMD-certified system which has the problem as per my “uncertified” Giga-byte GA-G1975X setup.
    Peter Corbett
    Australia
  • Peter Corbett
    June 18, 2006 at 1:17 pm
    One other thing. Moving the capture window around with the mouse or tablet during capture causes the “No Video Input” message to flash repeatedly. Could this be a co-incidence? Kristian?
    Peter Corbett
    Australia
  • Manuel Deo
    June 18, 2006 at 1:57 pm
    hi Peter,
    i’m frustrated too, because, i have install my card in diff
  • John Christie
    June 18, 2006 at 6:21 pm
    I have seen this occasionally on my G5 with a Dual link Decklink HD capturing SDI standard def. In my case, I only see it when I am capturing from a Sony 1500 DV deck via SDI. Mostly I capture from a Sony Digi Beta deck and haven’t seen the problem with that deck.
    Cheers
    John Christie
    Keyframes Editing
  • Manuel Deo
    June 19, 2006 at 7:18 am
    Hi John,
    Thanks for you information, because i digitalize with a sony 1500 deck.
    Do you think the sdi output of sony 1500 deck have problem of compatibility with the decklink sdi input ?
    So I have to test the sdi signal of sony 1500. Howether, i see the sdi output on my JVC monitor with sdi input and it seems good.
    I go to test the input with other sdi deck and i send you the result of my investigation.
    Maybe, here is the source of that problem.
    Regards
    Manuel
  • Peter Corbett
    June 19, 2006 at 7:26 am
    I don’t know Manuel, I get this on all inputs, not just SDI.
    Peter Corbett
    Australia
  • Manuel Deo
    June 19, 2006 at 10:18 am
    hi peter,
    i have do a last test which i readed in a post.
    i connect the decklink output ( which generate a black video) in the decklink input and there is the same result : no video input.
    so i think, i have a very big problem.
    I’m lost.
    thank for your help
    Ps : my decklink is the HD pro dual link model, and i just can test with the sdi iinput.
    I continue to believe in best issue for all of us
    regards
    Manuel
  • Mel Matsuoka
    June 22, 2006 at 5:19 am
    I too am getting the same “No Video Input” flashing issues (Decklink Pro card on a Dual 2.0Ghz G5, being fed an SDI signal from the Workgroup Videohub). In our case, it happens only when the FCP Log & Capture window is open. It just started happening all of a sudden for no apparant reason, and after exhausting all troubleshooting measures that I could think of, I broke down and re-installed the whole G.D. operating system from scratch, reinstalled FCP 5.1.1 and the newest BMD drivers…
    …but alas, the flashing STILL continues 🙁
    So what gives, good folks at BMD???
  • Manuel Deo
    June 22, 2006 at 9:24 am
    Hi Mel,
    Welcome to the Desesperate Office EndUser Life.
    At this time, i Haven’t resolved thiss prob of “No video Input”.
    Next Week, i do a last test with a special SDI Testing Equipment to check my Installation. I want to test diff
