Activity › Forums › DaVinci Resolve › Anyone get De-noise to work?
  • Anyone get De-noise to work?
    Posted by Peter Berg on April 26, 2011 at 10:11 pm
    Question about RED footage. I have some dark footage that I pushing quite a bit to brighten it up. It is getting a bit noisy so I tried to turn the De-Noise setting to Maximum. I didn’t see any change to the image. I switched between the mild and maximum and don’t really see a difference. Has anyone got this to work with their RED footage? At this point I would love to add some noise/grain to some of the other shots (from Canon 5D) in the scene to make it more consistent. Any tips on how to handle this situation?
    thanks,
    Peter
    Jake Blackstone replied 15 years, 5 months ago 7 Members · 8 Replies
  • 8 Replies
  • Christopher Tay
    April 27, 2011 at 1:51 am
    Where did you see this De-Noise feature in Resolve ?
    -chrispy
  • Peter Berg
    April 27, 2011 at 2:13 am
    It’s in the ‘Image Decoder Settings’ area of the RED Settings window.
    -Peter
  • Mikhail Puzyrev
    April 27, 2011 at 7:24 am
    I use neatvideo in FCP. Highly recommend.
  • Jose Lomeña
    April 27, 2011 at 7:38 am
    Try neatvideo at 4k, its really incredible, i recomend grading after denoise…
  • David Smith
    April 27, 2011 at 7:57 am
    I’ve used Neat Video too. It works so well I’ve wondered at times if there is some magic involved 🙂
    At lower resolutions it can make the image look a little “plasticy” if you use it at full strength (with 16mm film at least), I normally back it off a bit and put some of the grain back in – just a touch. I can imagine with HD it would be flawless.
    Neat video works so well it makes me wonder if it is the best thing on the market? It’s only 99 dollars and I have often wondered how it would stack up against far more expensive options.
  • Peter Berg
    April 27, 2011 at 5:50 pm
    Thanks for the suggestion. It doesn’t say it works on Avid or Resolve. Am I missing that? I only have access to the Resolve and Avid for these projects.
    I take it that the De-noise in Resolve is not really working?
    -Peter
  • Illya Laney
    April 27, 2011 at 10:03 pm
    From my experience de-noise in regards to RED doesn’t work the same as a typical de-noise filter. If you fool around with the setting in REDCINE-X you’ll see what I mean.
    twitter.com/illyalaney
  • Jake Blackstone
    April 27, 2011 at 11:53 pm
    Just wait till Resolve 8. It has a proper denoise node.
