Activity › Forums › Adobe Premiere Pro › Anyone familiar with TotalCode for Premiere?
Posted by Tom Daigon on July 6, 2012 at 6:01 pmAnyone familiar with TotalCode for Premiere?
https://www.rovicorp.com/products/distribution/content-production-tools/totalcode-for-adobe-premiere-pro.htm#overviewTom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3Tony Brecknock replied 13 years, 1 month ago 7 Members · 9 Replies -
Angelo Lorenzo
July 6, 2012 at 6:45 pmI’m not, but it looks interesting. For the price, the ability to do DCP packages is a steal. On the surface, it seems like a similar concept to Sorrenson Squeeze; Squeeze really only catering to delivery codecs.
Angelo Lorenzo
Fallen Empire – Digital Production Services
RED transcoding, on-set DIT, and RED Epic rental services. -
Tom Daigon
July 6, 2012 at 9:09 pmIt turn out to be a new Main Concept product.
https://www.mainconcept.com/en/products/apps-plug-ins/plug-ins-for-adobe.html
Tom Daigon
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Kona 3 -
Simon James
July 16, 2012 at 11:00 amHi Tom,
I work for Rovi. Yes, this is a new version of the Codec Suite plug-in. It’s a native Premiere Pro plug-in. The website does a pretty good job of listing out the main benefits (smart rendering, GPU encoding, format support including digital cinema encoding). It’s worth noting that the product comes as a base product with three add-on packs (including a digital cinema pack) just in case you think everything is included in the base product!
Compared to Codec Suite, TotalCode adds:
– CS5.5 and CS6 support
– OpenCL and Intel QuickSync Video support (Codec Suite was CUDA only)
– Expanded MXF support
– VC-3 support
– JPEG2000/Digital Cinema supportThe other nice benefit is that the product’s capabilities are also available in the Adobe Media Encoder which means you can export your After Effects projects using TotalCode (handy for DCP for example).
Hope that helps answer any questions you had!
Simon.
Rovi. -
Cassius Marques
September 4, 2012 at 6:16 pmHey Simon, I’m doing some tests with Totalcode running through AME cs6. Using the same preset I’ve used before and I’m getting different results in the outputed file.
My current broadcast specs are XDCAM IMX. My problem lies within the audio. I’m going for 4 channels 24bits.
With the previous version I had left, right, left, right.
With totalcode I get left, right, blank, blank.Can you shed some light?
Simon James
September 12, 2012 at 3:41 pmHi Cassius. That isn’t an issue I’ve heard of before. I suggest emailing the support team to investigate with them. Sorry I can’t be of more help!
Simon. -
Peter Neumann
September 21, 2012 at 8:00 amhi Cassius,
when you selected the IMX preset in the TotalCode Export settings dialog, did you make sure to adjust the PCM audio settings to 4 channels? The default presets are configured for 2 channel.
Regards,
Peter -
Cassius Marques
September 21, 2012 at 5:58 pmYes I did, I’ve actually tried every permutation possible…
The file comes out with 4 audio channels…but the third and fourth are muted instead of having the 1 and 2 mirroed.
Gil Reitsma
November 14, 2012 at 10:49 pmHi
Anybody been able to use this product with Windows 8?
It seems it does not. Does anybody at Rovi know when this will be addressed
Gil
Tony Brecknock
August 14, 2013 at 7:07 pmI am trying to get timecode out when I use Totalcode in Ppro 5.5. no matter what I do it doesn’t seem to want to do that when creating an .mxf. any help would be grateful.
Tony
