Activity Forums Apple Final Cut Pro Anyone else having export problems in new version?
  • Anyone else having export problems in new version?
    Posted by Mike Bonner on May 12, 2015 at 4:38 am
    Since updating, I have a project that results in a fail message when trying to render out to Apple devices (which I use to upload cuts for review). I can render out in other formats (such as ProRes), but when I do, there is no audio.
    I’ve tried creating new projects, copying, pasting, deleting preferences, etc.
    I’ve been traveling with an external drive between work and home (2013 iMac/ nMBP 6 core). Same problem on both machines.
    A new bug, or just me?
    Mike Bonner replied 11 years, 4 months ago 3 Members · 4 Replies
  • Noah Kadner
    May 12, 2015 at 4:47 am
    I’d blow away renders- that often clears it up.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Mike Bonner
    May 12, 2015 at 4:57 pm
    Update:
    I removed FCPX and associated files, reinstalled, and was able to create new projects that exported normally, however, the project I was having trouble with still wasn’t exporting. I tried copying event into a new library, as well as copying all clips into a new project. Same thing. I had success with exporting an XML of the project into a new library, it exported ok, but I got a long list of “frame boundary” warnings upon import of the xml.
    Any ideas what that’s about?
  • Jeremy Garchow
    May 12, 2015 at 5:05 pm
    Corrupt media?
  • Mike Bonner
    May 12, 2015 at 6:30 pm
    Corrupt Library?
    The same media exported fine when a new project was created with an XML. Whatever the problem was, going through the XML solved it.
