Activity Forums VEGAS Pro Anyone else had problems rendering nested projects?
  • Anyone else had problems rendering nested projects?
    Posted by Rick Mac on August 23, 2007 at 1:53 am
    I recently completed a 95 minute prom video. Early on I decided to edit it in small sections and then after all sections were edited pull the veg files up into a master timeline for rendering. This is where I started having problems. The individual veg files would open with no problem.
    But once I tried to render, after a while the render would stop and say there had been an error. It never stopped in the same place twice and the error messages were different.
    I was rendering DV to mpeg-dvda stream. Then I tried rendering dv to dv, same result, stopped with error.
    I could never find a pattern to it all.
    Not having time to play with it anymore I batch rendered the individual veg files to dv, then pulled all of them into a master project for render without a single problem.
    Anyone out there had problems rendering nested projects?
    If so, where you able to figure out how to make it work.
    I really liked the nested workflow if it would have rendered for me.
    Thanks, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
    Rick Mac replied 19 years, 1 month ago 3 Members · 5 Replies
  • Douglas Spotted eagle
    August 23, 2007 at 3:05 am
    Sometimes, some systems…nested veg files can tax your proc or system resources. I’ve found that setting threads to 1 or 2, generally makes this render hangup go away. i’ve got a monster project that has several nested XDCAM HD veggies in it that chokes if I don’t set Dynamic RAM to 0 and threads to 1.
    Douglas Spotted Eagle
    VASST
    Aerial Camera/Instructor
    Certified Sony Vegas Trainer
  • Lance Bachelder
    August 23, 2007 at 5:39 am
    Concur – couldn’t render a 1080p project until I set the threads to 1 and memory to 128
    Lance Bachelder
    Southern California
  • Rick Mac
    August 23, 2007 at 11:36 pm
    Douglas,
    As usual your advice was SPOT on (pun intended).
    Pulled that big nested project back up and set Vegas
    Options as you suggested. The entire thing rendered without a hitch. How in the world did you ever figure that one out?
    Thank you, thankyou. Now that I know the trick I can use nesting a lot more. You da man.
    Thanks again, Rick.
    Rick Mac
    August 24, 2007 at 4:11 am
    I ended up doing it based on what I saw in my ‘puter.
    Then I talked to a Sony engineer and his comment was “You didn’t know that already?” 🙂
    VASST
  • Rick Mac
    August 25, 2007 at 12:21 am
    [DSE/Spot] “Then I talked to a Sony engineer and his comment was “You didn’t know that already?” :-)”
    Sounds to me like you need to write another book. Possible titles.
    Vegas – Secrets
    Vegas – Settings the manual did’nt tell ya.
    Vegas – Tips & Tricks from the trenches.
    I’m still waiting for a really good one on Network Rendering
    and Decklink Workflows.
    By the way, I have been reading HDV-What you need to know, and am learning much for that jump to HDV.
    Also, my copy of Vegas Editing Workshop is my Vegas Bible. I can’t tell you how much that book has helped me.
    Between VASST teaching tools, excalibur, and Edward Troxel
    (my neighbor, I’m in tall cotton.
    Regards, Rick.
    Rick Mac
