Activity Forums VEGAS Pro Anyone else able to run Cineform on Vegas Pro 10?
  • Anyone else able to run Cineform on Vegas Pro 10?
    Posted by Don Cobble on October 11, 2010 at 10:28 pm
    I am not able to run Cineform AVIs on my new Vegas10. Nor will the Veg files that contain Cineform files load. Nor can I render out anything Cineform?
    Get the Following Error:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0a (Build 387)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files (x86)\CineForm\Tools\CFHDEncoder.dll
    Fault Address: 0x2750ECA4
    Fault Offset: 0x0008ECA4
    PC
    I7 2.8 Ghz 8GB Ram
    Vista 64bit OS
    Nvidia FX 580 Video Card
    3-4 TB HD
    Vegas Pro 9 32bit & Vegas Pro 9 64bit
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Don Cobble replied 15 years, 11 months ago 3 Members · 3 Replies
  • John Lenihan
    October 11, 2010 at 10:41 pm
    I am able to run cineform
    I downloaded vegas pro 10.
    I can open up the previous avi file created by cineform.
    I tried the avi files from a week ago, and the files from May, when I was using an older version of cineform.
    They open and play fine.
    However, I am not able to render anything into cineform AVIs because it says it cannot find a cineform codec.
    I am using the 32 bit version of vegas 0 on an xp machine.
    John Lenihan
    LeniCam Video Productions
    John Lenihan
    https://www.lenicam.com
  • Charles Biddle
    October 11, 2010 at 11:37 pm
    I have the same problem. WIll not read nor render to Cineform. It says no compatible codec found.
    Do either of you have NeoScene installed?
    I also looked at manually copying and pasting the cfhd.dll file into vegas like in the past when you installed a player, and it does no good as it looks for the new “compound.dll” from what I gathered over at Sony.
    So when is the Scarlett coming out again 2009, 2010, 2011…
  • Don Cobble
    October 12, 2010 at 2:05 am
    I am running NEOHD 4.3 Build 240 the latest and last update for NeoHD 4
    I cannot open or render any AVI made by Cineform, I am able to open AVI’s that are non cuneiform.
    I reinstalled cineiform that didn’t help. Still looking for an answer, by the way they have had terrific support since I have done business with them and they are looking into this now. I will post what I find out
    PC
    I7 2.8 Ghz 8GB Ram
    Vista 64bit OS
    3-4 TB HD
    Camera
