Activity › Forums › DaVinci Resolve › anyone done a red camera conforms from fcp via the mac resolve
  • anyone done a red camera conforms from fcp via the mac resolve
    Posted by Darin Wooldridge on September 22, 2010 at 10:07 pm
    Testing a little 4k red conform. Anyone have any tips for a 4k conform via a fcp edl?
    Darin Wooldridge
    Freelance Colorist / technical strategist
    Technicolor Digital Intermediates
    818-653-3918-cell
    DI.Colorist@me.com
    Andrew Huebscher replied 16 years ago 5 Members · 7 Replies
  • 7 Replies
  • Robbie Carman
    September 22, 2010 at 11:14 pm
    yeah I did this the other day on a short piece and everything worked just fine.
    Add all the R3Ds to the media pool. Take your FCP EDL and conform but make sure on the config tab and then settings you enable extract reel names from comments as the default 8 characters won’t cut it for the way the RED reels are named.
    Robbie Carman
    Colorist and Author
    Check out my new Books:
    Video Made on a Mac
    Apple Pro Training Series DVDSP
    From Still To Motion
    Twitter
    Blog
  • Margus Voll
    September 23, 2010 at 5:21 am
    Hi.
    I did it a bit different: ad to media pool by edl.
    Only used red files were added.
    Works perfectly.
    Margus
    https://iconstudios.eu
  • Darin Wooldridge
    September 23, 2010 at 7:06 am
    Thanks for the tips..
    Half the project links the other half red x’s.
    Trying to find the difference in the edl / paths. I did notice the firmware of the red camera changed half way through the project. Also to make it more interesting the project has some 5d and 3k red varispeed stuff mixed.
    Darin Wooldridge
  • Andrew Huebscher
    September 23, 2010 at 4:32 pm
    How does Resolve handle speed changes from FCP? Specifically, what happens if there is a dynamic change within a clip?
    Thanks in advance,
    Andrew Huebscher
    Los Angeles, CA
  • Darin Wooldridge
    September 23, 2010 at 7:45 pm
    Thanks everyone. Its working.. 🙂 4k, 3k and canon 5d material cut in final cut pro conform to the resolve for debayer to 2k dpx frames then final color correction.
    Still checking on the speed changes.
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@me.com
    Check my out on facebook @ davinci resolve colorist
  • Sascha Haber
    September 24, 2010 at 12:40 pm
    CMX 3600 EDls dont hold dynamic speed ramps, only static speed changes and those should work on every system.
    In those cases where footage is speed up we tend to make single frame cuts , those will work fine too.
    But if quality is king, you want a good offline, timecode and Red name visually embedded and use Kronos/speedo/twixtor.
    I tend to ask for non-speeded and speeded EDLs and always look forward to what the clients deliver 😉
  • Andrew Huebscher
    September 24, 2010 at 2:28 pm
    Thanks, Sascha and Darin. I went ahead and did made speed changes out of FCP. They didn’t translate exactly in Resolve, but the “compare to offline” feature made it easy to spot, and the conform tools easy to fix.
    Andrew
