Activity Forums Audio Anybody Using Kona for Audio Out?
  • Anybody Using Kona for Audio Out?
    Posted by Keith Pratt on September 2, 2010 at 3:25 pm
    Can anybody comment on using the analogue outs from a Kona card (specifically the LHi) to monitor audio? I’m particularly interested in D/A quality. I’m not expecting the world but if it’s subpar I’d prefer to run through a dedicated interface.
    Keith Pratt replied 16 years ago 3 Members · 3 Replies
  • John Fishback
    September 2, 2010 at 3:50 pm
    We use the AES digital signal from our Kona3 into our mixer which does the D/A and A/D. But as all the other aspects of the Kona are first-rate, I expect the analogue audio out would be perfectly fine. We use the analogue audio out from our older AJA IO and it’s excellent.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jean-christophe Boulay
    September 2, 2010 at 7:14 pm
    I don’t regularly use it, as most everything is done through the digital connections, but the analog audio quality is very good. There’s absolutely no need for a separate audio interface as far as audio quality is concerned.
    IHTH
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Keith Pratt
    September 5, 2010 at 9:06 pm
    Sounds like it’s definitely worth giving the Kona a go before looking into alternatives. Thanks for the replies.
