Activity Forums Blackmagic Design anybody useing 2 GHZ G5 PCI model not PCI-X
  • anybody useing 2 GHZ G5 PCI model not PCI-X
    Posted by Kushal Shah on December 16, 2005 at 3:46 am
    I was wondering If you guys share your experince useing G5 2 GHZ PCI which is discontinued now
    with decklink extreme and sonnet or atto cards?
    I have couple of them lying around and since new mac G5 doesnt have stable sata or scsi card readily available
    I wanted to put these to use in the facility.
    I would be happy if someone has used this config and share the experince
    Olivier Jean replied 20 years, 8 months ago 4 Members · 4 Replies
  • Kristian Lam
    December 16, 2005 at 3:57 am
    Hi Kushal,
    PCI only G5s are not supported. Kindly refer to this note:
    https://blackmagic-design.com/support/detail.asp?techID=76
    regards
    Kristian
    Blackmagic Design
  • Kushal Shah
    December 16, 2005 at 4:21 am
    HI Kristian
    I understand they are not supported officially
    I have managed to get one working on test basis
    so wanted to know other peoples experince
    Kushal
  • George Kalishkin
    December 16, 2005 at 1:08 pm
    This model doesn’t work with Decklink – it is my expierence.
  • Olivier Jean
    December 19, 2005 at 12:16 pm
    Kushal,
    do not waste your time with the PCI G5 Model !!
    you might have been lucky but might not be so lucky if this G5
    decides not to output your footage when you need it most….
    And your manager starts chasing you around with the tether cable…
    There is a reason why this is not a supported configuration.
    Regards
    Olivier Jean
    Video Sales Consultant
    Apple Certified Trainer Final Cut Pro 5
    Powermedia Systems
    Sydney Australia
