Activity Forums VEGAS Pro Anybody know how to do this effect?
  • Anybody know how to do this effect?
    Posted by Yohahn Ko on May 8, 2011 at 4:42 am
    I’m specifically talking about the effect that makes the line (underlining “TUTORIAL”) come out like that at 0:24-0:25. The guy said he used a mask.
    https://www.youtube.com/watch?v=Cketk456wAY
    If you know how to do it, I would greatly appreciate a video or steps (typed) on how to do this. Thank you
    Yohahn Ko replied 15 years, 4 months ago 2 Members · 2 Replies
  • Graham Bernard
    May 8, 2011 at 8:22 am
    1] Add new Track – say at Track 1
    2] Add Sample Text Generated Media SONY Text.
    3] Delete “Sample Text” and now type an Underscore Line that fills the whole screen, from left to right.
    . You should now have a Line on Screen. Yes?
    OK . .
    4] Click on the Pan/Crop Icon when it appears, Check/Select the Mask Timeline
    5] Now Add 4 Points, by using the Anchor Creation Tool, that create a boundary for the length of the Line.
    6] Hold Down the Ctrl Key and Drag a COPY of the Keyframe diamond say to 8 Seconds.
    7] Go back to the Initial Keyframe, and by draging each of the 4 Anchors Points separately, make the Line Disappear around the Centre of the Frame. Once you have done this you should NOT be able to see any of the Line.
    8] Play the 8 second sequence and what you should get is what I’m seeing too, and that is a Line “growing” equally in each direction AWAY from the middle of the screen as the Mask grows in size.
    Grazie
  • Yohahn Ko
    May 9, 2011 at 2:36 am
    Thanks for trying to help, but I wasn’t clear about your directions about draging the anchor points separately to the center of the frame and there on forth :/
