Activity Forums Apple Final Cut Pro Legacy Any wya to globally change clip names in browser?
  • Any wya to globally change clip names in browser?
    Posted by Michael Buday on November 8, 2005 at 1:20 am
    I’ve taken over a big project from another editor who used “/” in the names of many of his master clips to separate scene numbers. Unfortunately, this naming convention really screws with Soundtrack Pro (who in their right mind uses forward or backslashes in clip names???)
    Anyway, in the AVID or XPRI, I could perform a boolean search and replace of all the bogus clip names in one step. Is there any way to do this in FCP? I can FIND all the offending clips easily using the FIND function, but is a global REPLACE function??
    Many thanks
    All the best,
    Michael Buday
    Les Kaye replied 20 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    November 8, 2005 at 2:01 am
    Fraid not…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Dekkoman
    November 8, 2005 at 3:35 am
    You could try manipulating them at the Finder level by writing a script (easy) with Automator. You’d then have to re-import your footage though, which might reek havoc with your timeline.
  • Andy Mees
    November 8, 2005 at 1:24 pm
    the power for this kind of thing lies in the Export > XML… option
    if you have any applescript experience, or basc coding skills, you could write an applescript to handle doing this with an xml of your project file.
    at a more basic level you could even try just taking that xml and doing a “find and replace” on it.
  • Jerry Hofmann
    November 8, 2005 at 2:03 pm
    I thought of this too Andy…But it would still be a problem relinking, depending on just how many edits are in the sequence and how many clips you’d need to reconnect, this could be a bit cumbersome… might be faster to just rename them in Browser.
    Jerry
  • Andy Mees
    November 8, 2005 at 3:05 pm
    yeah, i’d definately have to test it personally… but seems it could be doable if working on an xml of the project as that should affect both the clips and sequences equally making the relink unnecessary (I think it would require a somewhat selective find and replace as one wouldn’t want to change the name of the source)
    a bit too busy at the moment, otherwise i’d have a bash a knocking up an AppleScript Studio based app to put a GUI on the idea.
    bet the guys and gals from Spherico could do it overninght!
  • Andy Mees
    November 8, 2005 at 3:24 pm
    ok, so a gui would be nice, but the basic premiss is sound as a pound
    created a project with some test media
    created a timeline with random application of clips applied multiple times
    exported project as xml
    opened xml file in a text editor and did a find and replace on one of the known clip names
    replaced every instance except the “parthurl” item
    saved changes
    double clicked the xml, told fcp to create a new project and checked the reconnect media box
    everything was exactly as before except the clip name had changed globally, reveal in finder linked back to the original file
    cool.
  • Michael Buday
    November 8, 2005 at 6:44 pm
    Andy, wow – thanks so much for taking the time to test that work flow for me. I will try that next time this problem arises. Last night, I had to make a decision, so I went ahead and did it the cumbersome way. I did a global search and replace at the FINDER level to fix the media file names, then I manually changed all the clip-names in FCP (ughh!), then spent several hours relinking all the clips and sequences to the new media file names.
    This is where AVID really learned their lesson a long time ago. Many people don’t know this, but you actually change the name of a media file at the OS level while the Avid is playing that file, and it will automatically re-link to the new name without user intervention. This is because Avid doesn’t rely soley on the name of the file, since it can be so easily screwed up when transferring between systems, OS’s ,etc. Instead, if it can’t find the file by name, it looks into the file header where it stores a GUID that can’t be screwed by the user or the OS.
    Apple should adopt this kind of robust media file linking! Other then that though, I’m pretty happy with FCP so far!
    Again thanks . .
    Michael Buday
  • Les Kaye
    November 9, 2005 at 3:49 pm
    [Michael Buday] “This is where AVID really learned their lesson a long time ago”
    Well, it wasn’t all that long ago. If you recall, Avid’s file naming used a hexidex convention that made it just about impossible to know what a file on the desktop was. They finally cleaned it up (I think).
