Activity Forums Maxon Cinema 4D Any Way to Stop sIBL Random Reflectance?
  • Any Way to Stop sIBL Random Reflectance?
    Posted by Jay Vill on December 10, 2018 at 7:11 pm
    So I’m rendering an animation sequence using sIBL.
    But the thing is that the reflective layer – sIBL_RESky, is randomly rotated or moved during each seperate frame. But I want it consistent so that the snow I have made doesn’t sparkle.
    As you can see, the reflectance is randomized?
    I’ve tried making the layer only seen by GI, seen by Camera and Rays, making it seen by reflection and AO, but nothing makes it stays still, or changes make the reflective layer disappear.
    I’ve also tried toying around with the render setting and moving stuff and changing the irradiance cache and sampling but nothing really changes.
    Does anyone have suggestions? Or is this simply a software plugin limitation that is unchangeable?
    Here’s a previous file upload where this is present also.
    12914_snowtest.zip
    Jay Vill replied 7 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
