Activity › Forums › Adobe After Effects › Any way to select custom time span by default?
  • Any way to select custom time span by default?
    Posted by Jimmy Brunger on November 6, 2013 at 8:01 pm
    Hi all,
    Quick one this – is there any way to set render settings template so it defaults to custom time span rather than work area or length of comp?
    I’m outputting dozens (hundreds probably) of sections of comps as in/loop/out states using markers along the comp, setting work area then render that selection…I currently have to hit ‘set to custom’ every time, but would speed things up massively if that was default.
    Wouldn’t be a problem, but there’s several ‘sections’ of the same comp going into the render queue at a time, so if I don’t check custom then the latest work area set will be applied to everything in the queue…if that makes sense!
    Thanks for any help anyone can offer.
    Adobe CC
    MacPro 3,1 8-core 3.2GHz / 32GB RAM / NVidia Quadro 4000 / OSX 10.8.5
    Decklink Extreme+ 3D / 3TB RAID-0 local / 6TB XServe + United Digital RAID on 10GbE
    Jimmy Brunger replied 12 years, 10 months ago 3 Members · 6 Replies
  • Walter Soyka
    November 6, 2013 at 8:13 pm
    1) Go here:
    https://www.crgreen.com/aescripts/
    2) Download Queue_Comp_Sections.jsx
    3) Create some guide layers in your comps instead of using the markers. Name them what you want the exported file name to be, and set their ins and outs where you want them to begin and end.
    4) Select the guide layers, then run the Queue_Comp_Sections you downloaded above.
    5) Go back to Chris’s site, click the Donate button, and send some money Chris’s way to compensate him for sharing his scripts and saving you so much time.
    Walter Soyka
  • Todd Kopriva
    November 6, 2013 at 8:33 pm
    Yes, that.
    I just did it.
    After Effects team blog
  • Jimmy Brunger
    November 6, 2013 at 8:55 pm
    Thanks Walter, although I think it might be a bit late for that approach now…All my 20+ comps are derivatives of the original master, so all markers same in each and each clip will have a unique name. Think this approach might take as long or longer on this occasion.
    But will defo bear in mind for next time. Thanks!
    Can’t believe this ‘set custom time’ thing isn’t a tickbox in AE prefs or something. Each extra ‘click’ you can avoid with stuff like this soon ad up!
    Adobe CC
  • Todd Kopriva
    November 6, 2013 at 9:47 pm
    Here’s the feature-request form:
    https://www.adobe.com/go/wish
  • Walter Soyka
    November 6, 2013 at 10:05 pm
    [Jimmy Brunger] “Think this approach might take as long or longer on this occasion.”
    If you’re really ready for final render, yes, it will probably take more time than it’s worth.
    If it turns out that there’s another round of tweaking, though… with the markers all in the same place, you could at least copy and paste the guide layers. You’d still have to rename them, of course.
    Walter Soyka
  • Jimmy Brunger
    November 6, 2013 at 10:14 pm
    Thanks again guys. Will definitely try it for the next one
    Adobe CC
