Activity › Forums › Adobe After Effects › Any way to replace a layer's solid source ?
Posted by Martin Dumas on January 23, 2023 at 4:50 amI only need one solid for my project. Currently, all my layers are using a different solid. Is it possible to change the layer’s solid source, either via UI or script ?
Walter Soyka replied 3 years, 7 months ago 3 Members · 4 Replies -
Dan Ebberts
January 24, 2023 at 1:30 amMaybe just Alt+drag from the Solids folder in the Project panel onto the layer?
Martin Dumas
January 24, 2023 at 2:46 amEww. So easy 🙂
I failed to realize that the layer needs to be selected.
Thanks !Do you know how to do it by script ?
Dan Ebberts
January 24, 2023 at 5:02 amIt depends on how you want to do it exactly. Here’s an example that replaces layer Solid 2’s source with layer Solid 1’s source:
var myComp = app.project.activeItem;
var source = myComp.layer("Solid 1").source;
myComp.layer("Solid 2").replaceSource(source,false); -
Walter Soyka
January 24, 2023 at 7:16 pmDan has mentioned how to swap sources inside a comp, but you can also do this across the entire project in the Project panel. Select the item/solid that you want to keep, hold Alt, and drag it onto the item/solid that you want to be replaced. Every instance of the second item throughout the entire project will be replaced with the first.
