Activity › Forums › Apple Final Cut Pro Legacy › Any way to override?
  • Any way to override?
    Posted by Shakespeare on August 26, 2005 at 11:11 pm
    I would like to add an additive dissolve….
    However, it keeps giving me the error message there is insufficent media.. Is there anyway to override this and add the dissolve anyway, or am I just hooped?
    Thanx in advance.
    shakes
    Frank Pledge replied 21 years, 1 month ago 5 Members · 5 Replies
  • Jerry Hofmann
    August 27, 2005 at 2:16 am
    You have to have enough unused media to perform a transition… either capture more of each clip or delete some of each side until you have half of what the duration of the transition is unused in the timeline…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Blub06
    August 27, 2005 at 4:03 am
    You could just put the first shot on an upper video track and leave the next shot on a lower video track, and just put the dissolve on the end of the top clip. Of course if there is not enough incoming media the dissolve will snap off for an excellent example of really bad unprofessional work.
    Chris
  • Shakespeare
    August 27, 2005 at 4:16 am
    hmm..
    thanx for the reply’s guys, but it looks like im hooped. Bulb’s idea sounds like it might work, but “an excellent example of really bad unprofessional work” isnt quite the look im going for 😛
    As for Mr. Hofmans post, that makes sense to me. Problem is, I am trying to work with clips that are being captured from an already complete source to make a music video. The clip I have was already too short, I had to “fit to fill” it to the sequence of the song as is, so capturing more of it isnt an option. It was too short to begin with.
    As always, thanx for the insight folks… guess this time Im just up the river.
    shakes
  • Erik Jägberg
    August 27, 2005 at 1:41 pm
    You cuold get more material by slowing one or both clips down a bit, or add a freeze frame, or…
    There are many ways to skin a horse 😉
    /Erik
  • Frank Pledge
    August 28, 2005 at 8:23 pm
    what you do is slow down a bit the head or tail (whichever end we’re talking about). your goal is to get as much of the slow stuff in the dissolve itself. how slow? experiment.
    fp
