Activity Forums Apple Final Cut Pro Any way to offset the automatic audio sync?
  • Any way to offset the automatic audio sync?
    Posted by Kyra Dunn on January 8, 2014 at 3:03 am
    I have footage shot on a 5D where the audio is 2-3 frames out of sync from the video. Anyone who has used this camera has probably run into this.
    On the slate the audio is two frames early. When I sync automatically it sync’s to the camera’s audio, making the sync’d production audio two frames off. If I put on markers that compensate for this, it still seems to default to the original audio waveform from the camera for the sync reference.
    Is there a dialog box somewhere to tell FCPX to add a plus or minus “X” amount of frames in the process?
    I’m not seeing a way around this.
    Any help would be appreciated.
    ALSO, Please note that I am not talking about drift or differing sample rates. Thanks in advance.
    Kyra.
    Dave Jenkins replied 12 years, 8 months ago 2 Members · 1 Reply
  • Dave Jenkins
    January 8, 2014 at 4:49 pm
    I haven’t done sync in an event but did you try “open in timeline” by right clicking on the clip?
    Dajen Productions, Santa Barbara, CA
    MacPro 3.2GHz Quad Core – AJA Kona LHe+
    FCS 3 OS X 10.7.4
    FCP X, Logic Pro, Squeeze, Filemaker 10.8.3
