Any way to make a clip speed even faster?
Good evening guys, I’m making a montage video in like a meme format. So I have to speed up this part and insert some elevator music on top of it (because it’s a boring scene / dead air) and my approach is by squeezing the video event (dragging the edge with Ctrl, so it speeds up both video and audio). Usually this is enough, but this time the dead air is quite long, so the usual squeeze method I do is not enough sincce it is capped at 400% the original speed. Then I find out about Envelope > Velocity, which gave me a satisfying 1000% speed up. However, this only applies to the video and not the audio… I need the audio to be synced while speeding up the clip so the sped-up sound is not out of place, can anybody help me with this?
