Activity Forums Adobe After Effects Any way to loop video?
  • Any way to loop video?
    Posted by Tl Westgate on February 20, 2008 at 2:03 pm
    I have an animated background that’s about 20 seconds. But I need it to loop in the background for half an hour. Is there an easy way to loop it? Or do I have to duplicate it a bunch of times?
    Kevin Camp replied 18 years, 7 months ago 3 Members · 3 Replies
  • Steve Roberts
    February 20, 2008 at 2:08 pm
    Select the imported footage in the Project window, then File>interpret footage>main. Set it to loop there.
  • Tl Westgate
    February 20, 2008 at 2:33 pm
    Perfect! Thanks!
  • Kevin Camp
    February 20, 2008 at 6:21 pm
    additionally, you can select the background footage in the comp, select layer>time>enable time remapping… then select the time remap property that pops up for that layer and enable expressions for it (animation>add expression) then type loopOut() in the expression field.
    the clip will loop for the duration of the comp. if you adjust the length fo the comp, you may need to extend the length (out point) of the layer (as you would with any layer).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
