Any way to import AVCHD as standard definition ProRes?
Here’s the deal, 99% of my work is weddings and other events where the final product is going to DVD. Most folks apparently still don’t have blu ray players and in the last three years have only been asked once to create a blu ray.
Well, I started using DSLRs a couple of years back and recently replaced a Sony FX7 with a Canon XA10 and now I find that I’m having to edit everything in HD (which slows down the editing process and consumes massive amounts of disc space) when it’s totally not necessary.
So the question is, is there any way to force FCP to import the files from the XA10 (AVCHD 1920×1080) in standard definition? I’ve tried using MPEG Streamclip and several other conversion applications to batch convert them for me, but I can never seen to come across the perfect setting. The footage always seems to either come out blocky, pixelated, apparent interlace lines….something.
I’ve tried converting to DV codec…but I have to do 853×480 because of the way DV handles the strange “anamorphic” aspect of DV 16:9. DV codec also has nasty jagged edges which I cant stand. I’ve also tried going to 720×480 ProRes but it comes out 4:3 (which totally baffles me since 720×480 is the exact pixel size of a widescreen DVD, 640×480 being non-widescreen).
So pretend for a moment that you shot an entire job on an XA10 in AVCHD 1920×1080 60i and you want to edit for DVD. What workflow would you follow? (other than editing in HD and resizing it in compressor).
