Activity Forums Apple Final Cut Pro Legacy Any way to identify if there are H.264 on the timeline?
  • Any way to identify if there are H.264 on the timeline?
    Posted by Max Frank on November 16, 2011 at 8:18 pm
    I’ve been very careful to transcode all my DSLR footage to ProRes before adding it to the timeline, but I’ve been have Crash-O-Rama over here, and the Crash Analyzer tells me there may be H.264 clips on the timeline.
    Is there an efficient way to check the hundreds of clips in the timeline and see if there are, indeed, any H.264 clips that may have slipped in?
    Wayne
    Max Frank replied 14 years, 10 months ago 3 Members · 3 Replies
  • Neil Patience
    November 16, 2011 at 9:12 pm
    One thing to try is this.
    Make a copy of your sequence – not strictly needed but I always do this for safety.
    Create a new bin, highlight all clips in your sequence and drag them to your new bin.
    You will then have a list of what is in the sequence and you can check for H264 in the Compressor column.
    You can then safely delete these once investigated.
    best wishes
    Neil
    http://www.patience.tv
  • Mark Suszko
    November 16, 2011 at 9:34 pm
    Can’t you just click the properties tab on them?
  • Max Frank
    November 16, 2011 at 9:35 pm
    Great stuff – just what I was looking for.
    Tx,
    W
