Activity › Forums › VEGAS Pro › Any way to “dither” Sony DV(NTSC) color subsampling?
  • Any way to “dither” Sony DV(NTSC) color subsampling?
    Posted by Rick Anvican on February 28, 2014 at 11:52 am
    Hi all,
    I have a completed project as requested by my client, to be rendered in Sony DV(NTSC), the project contains digital scans of red-colored handwritten calligraphy (which are very thin), on a black background.
    From my understanding, DV(NTSC) uses color subsampling of 4:1:1 and this consequently showed relative artifacts, the dominant one being that the calligraphy having sharp edges, causes the red color to sometimes bleed into the black BG appearing crimson and the black from the BG bleeding into the calligraphy appearing as gray.
    Without changing the export format or the content within the project, is it possible to “dither” or smooth out the colors so that the calligraphy retains visibly its original red appearance? Most of it now shows up as gray-colored because of the subsampling selecting the black BG color more often.
    Thanks in advance.
    Rick Anvican replied 12 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    February 28, 2014 at 1:44 pm
    [Rick Anvican] “Without changing the export format or the content within the project, is it possible to “dither” or smooth out the colors so that the calligraphy retains visibly its original red appearance?”
    You can try adding a Gaussian Blur at about 0.002 to the text event but that’s about it. Thin lines and NTSC DV video do not go well together due to the interlacing and the low 480 line resolution.
    Not sure how you plan to deliver this but if you further deliver it on DVD it will only get worse because DVD MPEG2 will use 4:2:0 sampling and your 4:1:1 becomes 4:1:0. Just something to watch out for.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    February 28, 2014 at 2:14 pm
    Also, gently inform the client that red on black is probably the worst color combination for text on video.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Rick Anvican
    March 1, 2014 at 12:58 am
    Thanks for the tips guys, I’ve heard about the Gaussian blur trick some time ago, was thinking of applying linear blur (horizontally).
    [Stephen Mann] “Also, gently inform the client that red on black is probably the worst color combination for text on video.”
    Stephen, I have informed the client about the color combination, but I’m just doing what was requested. We’ve negotiated and opted for red but with slightly less saturation than before which reduced the color bleeding a bit, and as everybody knows, DV does not like overly saturated reds.
    The final delivery format was to be DV(NTSC) but I’ve tried rendering to DV(PAL) first then re-rendering the DV(PAL) version to DV(NTSC), reds were retained in the calligraphy in exchange of more color bleeding on the black BG, not a good idea but the calligraphy did visually appear in red more often than if rendering straight to DV(NTSC) where at least half of it was gray…
  • John Rofrano
    March 1, 2014 at 1:25 pm
    [Rick Anvican] “Thanks for the tips guys, I’ve heard about the Gaussian blur trick some time ago, was thinking of applying linear blur (horizontally).”
    The nice thing about the Gaussian Blur is that the horizontal and vertical are separate parameters so if you only set the horizontal blur then you will just get a linear blur in that direction. I would actually use a vertical blur since your problem is probably caused by this horizontal scan lines so you want to blur in the direction perpendicular to the problem so that it blurs across scan lines.
    ~jr
  • Rick Anvican
    March 2, 2014 at 9:14 pm
    Thanks John, this blur trick kind of reminds me about Reduce Interlace Flicker in Vegas…
  • John Rofrano
    March 3, 2014 at 4:49 am
    [Rick Anvican] “this blur trick kind of reminds me about Reduce Interlace Flicker in Vegas”
    Yes, it solves the same problem. Interlace Flicker is caused by lines that are only 1 field thin and a vertical blur helps smear the lines so that they are a bit thicker and appear on both fields.
    ~jr
  • Rick Anvican
    March 3, 2014 at 11:08 pm
    I’ve heard somewhere, probably on the forums that Reduce Interlace Flicker doesn’t always work as expected, the Guassian blur tricked worked well anyway, thanks again John.
