Activity › Forums › Adobe Premiere Pro › Any way to auto sync multiple video and audio clips (like in Avid)?
Posted by Scott Clements on February 17, 2015 at 3:10 amHi,
Premiere newbie here… I’m syncing clips in Premiere and can’t figure out a way of selecting a ton of clips and syncing them all at once (like in Avid Media Composer). Is there any way to do this?
Film Editor, London UK
http://www.scottclementseditor.comScott Clements replied 9 years, 10 months ago 6 Members · 9 Replies -
Tero Ahlfors
February 17, 2015 at 4:59 am -
Scott Clements
February 17, 2015 at 5:13 amIt doesn’t appear you can do what I’m talking about. In Avid, you can select multiple audio and video clips all at once and autosync them based on timecode. The document you pointed me to says you can sync multiple video clips to a single piece of audio, which isn’t the same thing.
http://www.scottclementseditor.com -
Tero Ahlfors
February 17, 2015 at 9:36 amYou can leave a feature request here https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&loc=en
Scott Clements
February 17, 2015 at 12:42 pm -
Joey Gibson
February 18, 2015 at 5:35 pmHi Scott,
I may have only misread what you’re asking for, but it looks like this could be it.
Hope this helps!
Jared Ganem
February 19, 2015 at 3:26 pmHey Scott,
I ran into the same problem. I thought you could do it with Premiere but you can only do one audio track, not multiple.
This solved my problem, it’s a program called Pluraleyes. I got excited about it and made a how-to video
Hope it helps
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tony Manolikakis
February 20, 2015 at 2:32 pmCheck out sync-n-link from intelligentassistance/assisted editing. If you have TC on your media this is a massive time saver.
Tony Manolikakis
Rev13 Films -
Lorrin Braddick
November 7, 2016 at 10:05 pmHey Scott,
Don’t suppose you got any further with this?
I ran into exactly this problem, only solution I’ve found is Pluraleyes… which isn’t ideal (gets messy, loads of tidyup afterwards, costs money for 3rd party etc).
Anyone get any further with this? Seems to be a pretty obvious function that’s been overlooked for a while in Premiere.
ta
L“Those aren’t pillows!!!”
Scott Clements
November 14, 2016 at 2:24 amSorry for the delayed response, Lorrin. I didn’t have any luck with this. I’ve been working on an Avid show for quite some time, so have stepped out of that territory for the time being.
