Activity Forums Adobe After Effects Expressions Any volunteers to make VC’s Sure Target compatible with JavaScript?
  • Any volunteers to make VC’s Sure Target compatible with JavaScript?
    Posted by David Cabestany on August 6, 2021 at 10:31 pm
    I’m not sure if this is allowed but wanted to ask if any of the coding heavyweights in the forum would be willing to tweak the code of VideoCopilot’s amazing free plug-in Sure Target. As it is right now it only works if you change the expressions engine to Legacy ExtendScript, which obviously breaks several other expressions that only work with JavaScript.
    I emailed about them and while they said it might happen in the future, it is low in their list of priorities.
    I would do it myself if I knew anything about coding, but alas, that’s not the case.
    If anyone has some time to kill and do a solid to the AE community I have attached the plug in here.
    David Cabestany replied 5 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
