Activity Forums Adobe After Effects Any Tuts On Writting Plug-Ins In AE????
  • Any Tuts On Writting Plug-Ins In AE????
    Posted by Carl Sollenberger on April 7, 2006 at 6:35 am
    There is a system of color tweaks, mode adjustments, and blurs that I like to use on some of my layers of DV footage….
    I was wondering if I could write my own plug so one step is all it takes????
    Any body done a tut on writing very basic plugs in AE????
    Thanks a lot
    Barend Onneweer replied 20 years, 5 months ago 3 Members · 3 Replies
  • Alon_a
    April 7, 2006 at 7:16 am
    Are you sure you want to actually write a plug-in? There is some SDK documentation on the Adobe website, but for what you describe this hardly seems necessary. Apply the effects to one layer and save them as a .ffx preset which you can then apply to the other layers, or use an adjustment layer, or if all else fails write a script – this is still much easier than an actual plug-in. Scripting is covered in the AE docs, and also over at Dan Ebberts’ site, particulary this section:
    https://www.motionscript.com/ae-scripting/table-of-contents.html
    – AA
  • Carl Sollenberger
    April 7, 2006 at 8:25 am
    Thank you.
    Yea – I thought it might be fun to try and write a plug or two…
  • Barend Onneweer
    April 7, 2006 at 10:32 am
    I think all AE plugins are written in some flavour of C.
    What you want is called “macro’s” in Shake, and “capsules” in Combustion. You build a concoction of existing plugins, build a custom UI around it (similar to expression controls), and wrap it into a single item.
    But AE doesn’t do this. Sending in feature requests may help though 🙂
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
