Activity › Forums › Adobe After Effects › Any tricks to fix over-sharpened video?
Posted by Perry Kroll on September 16, 2014 at 10:44 pmI’m working on a project with a ton of mixed media sources, and some clips were shot on a Canon Rebel that unfortunately had sharpening turned up all the way in the shooting profile.
Anyone ever come up with a clever way to at least partially fix this?
Harry Fear replied 8 years, 6 months ago 4 Members · 8 Replies -
Chris Wright
September 17, 2014 at 12:54 amfind edges, shift alpha as luminescence, levels-alpha white/black. set as alpha matte for fast blur .2. should smooth the black edges.
Perry Kroll
September 17, 2014 at 5:14 pmWorks like a charm! Crappy footage now slightly less crappy. I also blurred the matte layer a bit which seemed to work better for my situation.
Daniel Gregory
January 19, 2015 at 9:51 amIs there anybody here that could expand on this? I am having the same problem but the solution that Chris gave doesn’t quite go into enough detail for a new guy like me!
Chris Wright
January 19, 2015 at 2:15 pm -
Daniel Gregory
January 19, 2015 at 2:47 pmThanks for sending that through Chris. Sorry, I’m pretty new to After Effects, is there a simple way to explain how I use one of my video files with your template to try it out.
Chris Wright
January 19, 2015 at 3:14 pmRight click replace image sequence with footage, then controls layer has sliders. The comp is hd so you may need to resize as nessessary
Harry Fear
March 14, 2018 at 1:09 pmFolks, I’m dealing with a similar problem.
Footage was over-sharpened in-camera on the DJI Osmo. [The cameraman made a mistake.]
I’ve tried the AE template but all I see is a weird coloring effect and no effect to image sharpness.
I see the edge blur, texture, color, grain, on/off effects applied. But I don’t see any real effect on the footage:
with on/off on: https://image.ibb.co/jYp5cx/Screen_Shot_2018_03_14_at_13_01_38.png30.png
with on/off off: https://image.ibb.co/fBFdxx/Screen_Shot_2018_03_14_at_13_01_
original footage: https://image.ibb.co/d2vNPc/Screen_Shot_2018_03_14_at_13_05_57.pngAny ideas?
“find edges, shift alpha as luminescence, levels-alpha white/black. set as alpha matte for fast blur .2. should smooth the black edges.”I believe your instructions will work, but could you break them down so I can recreate them?
