Activity Forums Adobe After Effects Any Tips to Cut Down Render Times?
  • Any Tips to Cut Down Render Times?
    Posted by Chris Massa on July 14, 2017 at 4:10 pm
    I’m aware that AE normally takes a good while to render anything, but I’m on a deadline, so anything I could be doing more efficiently to render out the comp is appreciated. I have about 8 comps in the neighborhood of 5min. that and each 5min. comp is estimated to render in about 5 hours. The project is a green screen replacement.
    My project consists of the source footage brought in After Effects (all these layer have been pre-comped and pre-rendered), the Mattes (depending on the comp 2-3 layers with keylight combined into one key, this is all pre-comped and used as a luma matte), Dispelled footage which is two layer of the source footage, one with channel mixer applied and set to darken to remove the green, this pre-comp has color balance, lumetri, noise removal, and unsharp mask. The background plate has been baked and it is also used for a light wrap.
    I’m rendering out to a TIFF sequence for safety in case of any crashes. While rendering the preview window has been turned off.
    My machine has a i5-6500 running at 3.2 GHz, 32GB of RAM, and a GTX 970 although I realize it’s not really used for final renders. CPU usage has stayed below 80%. 28GB of RAM have been allocated to AE. My footage and output are on the same internal HDD, not ideal, but what I have to work with.
    Again, I realize that my render times may be the best I can get, but any advice to cut them down a little is greatly appreciated.
    Hanna Dean replied 9 years, 1 month ago 2 Members · 1 Reply
  • Hanna Dean
    July 14, 2017 at 10:36 pm
    u have 5 comps try like this.
    start on 1st comp go inside , of course all effects are in comp1 you wil se that .
    disable view for all comp and start to render 2 to 3 layers as avi once rendered import that avi to its original position in comp and disable the active comp.
    and then move on up ,doing same process , this works fast
