Activity › Forums › Adobe After Effects › Any tips on creating a evaporating fx
Posted by Brian Tetamore on November 17, 2005 at 1:36 amAnyone have any tips or suggestions on how to create an effect where a layer/object appears to evaporate? maybe there is a plug-in for this effect?
Michael Szalapski replied 20 years, 9 months ago 3 Members · 2 Replies -
Lee115
November 17, 2005 at 2:46 amWhat if you made a few layers of the thing you wanna evaporate, cut them up into more layers and then apply blurs to the different sections.
Maybe.I think there is a tutorial about doing a similar thing with particle illusion
Josh.
Michael Szalapski
November 17, 2005 at 3:28 pmAs Lee said you can make something evaporate with ParticleIllusion. (There’s a tutorial by Elvis Deane around here somewhere…)
You could also do it with fractal noise.
Create a new solid and apply fractal noise to it. Keyframe the evolution and the offset and other things to make it sorta steamy looking.
Precomp that layer.
Now apply two effects to your layer-to-be-evaporated.
1. Distort-Displacement map
2. Blur-Compound blur
For the map on both of these use your precomp (I’m sure you titled the precomp something intelligent like, ‘fractal’ or ‘noise’, right?)
Adjust the amount of displacement and blur and keyframe them both to go from naught to some big amount.
Also keyframe the opacity towards the end of the animation to make it disappear.I don’t have AE on this particular computer so I hope my directions are clear enough and the names of the effects are correct; if not, sorry.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
