Activity Forums Apple Final Cut Pro Legacy any tips for moving from g5 to mac pro?
  • any tips for moving from g5 to mac pro?
    Posted by Bill Depalma on October 10, 2006 at 12:39 am
    I will be switching soon to the mac pro from a g5. I am wondering if there is anything I should do to make the transfer as smooth as possible.
    For instance can I simply drag and drop my old applications into the new computer or do I need to reinstall from scratch? I mostly use FCS and Adobe apps but I am also concerned about reinstalling all the plug-ins with all of their own serial #’s. What a nightmare. Any thoughts on the best procedure?
    thanks
    Bill
    Bill Depalma replied 19 years, 11 months ago 3 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    October 10, 2006 at 1:31 am
    First off youo need the newist version of FCP for the Mac Pro (v5.1) the older versions will not run on the new intell processers.
    the easy way is to just use the migration assistant when you start up the mac pro for the first time
    however the adobie apps and the apple pro apps are ones that you will want to reinstall anyway for then to work properly
  • Chris Babbitt
    October 10, 2006 at 2:42 am
    I’m in the same situation as you, Bill. One thing I’ve learned that is not widely publicized, at least from the maufacturers, is that any plug-ins which are based on the After Effects architecture, will not run on the Intel machine. This includes all the Boris Apps.
  • Bill Depalma
    October 10, 2006 at 3:11 am
    thanks, I knew I’d be in for a few headaches, I have not done this switch in a couple of years. Certain plug ins like automatic duck can be so difficult to move to another machine
    now where are all those serial #s?
    thanks
    Bill
