Activity Forums Apple Final Cut Pro Legacy Any tips for creating sharp (not fuzzy or blurry) Titles in FCP?
  • Any tips for creating sharp (not fuzzy or blurry) Titles in FCP?
    Posted by Lawrence Richards on February 14, 2012 at 12:54 am
    Hey All,
    As the subject line says, I am wondering if anyone can offer any tips for how to make simple titles look really sharp? Are there certain colors/fonts to stay away from? Any particular settings? The reason I ask is because often the titles look kind of fuzzy or blurry.
    Thank you!
    Thank you!
    Larry R.
    Florida
    Shawn Bann replied 14 years, 2 months ago 3 Members · 4 Replies
  • Shane Ross
    February 14, 2012 at 1:26 am
    What are the sequence settings that you are working with? Size…dimensions…codec (codec is key!)
    Shane
    Little Frog Post
  • Lawrence Richards
    February 14, 2012 at 1:33 am
    Hey Shane,
    I’m not sure of the codec of the timeline as I let FCP match the settings of the raw footage. I can tell you the size and codec I converted it to though.
    Thank you!
    Larry R.
    Florida
  • Shane Ross
    February 14, 2012 at 1:38 am
    Open the SEQUENCE SETTINGS…that’ll tell you.
    And you don’t know the codec/size of the footage you are working with? That’s info you need to know.
    Shane
    Little Frog Post
  • Shawn Bann
    February 14, 2012 at 2:23 am
    I’ve always found FCP’s titles to leave much to be desired.
    Red text can be a nightmare (across all codecs)
    The best method I have found is using AE/Photoshop.
