Activity › Forums › Adobe After Effects › Any thoughts on the way this was done.
Posted by Aaron Keeny on April 25, 2008 at 1:21 pmThis is a ad for Liberty mutual, wonder if anyone has any thought on the best method of recreating something like this. I am referring to the end graphic with the blocks flying in and stuff. I was wondering if its a camera move zoom through/past the blocks and words or a scale and position change or a combo of both. Ive been trying it as a camera movement but it seems to be difficult to position everything just thought there may be an easy way to do this.
https://youtube.com/watch?v=wMwoexR1evo
Thanks. I Love the cow
Aaron Keeny
Aaron Keeny replied 18 years, 3 months ago 5 Members · 10 Replies -
Darby Edelen
April 25, 2008 at 8:08 pmMy guess is that there is a camera move involved, but probably not exclusively. If you can animate the blocks coming together into the logo in 3D space in a pre-comp, then nest that and collapse transformations you should be able to make your camera move separately from the logo animation… Nice and clean =)
Also, you could try using the Transition > Card Wipe or Simulation > Card Dance effects to create the logo animation.
Darby Edelen
Lead Designer
Left Coast Digital
Santa Cruz, CA -
John Felt
April 25, 2008 at 11:07 pmHaha, I actually saw that ad independently and was thinking about how you could do that effect with card wipe.
Card wipe is ostensibly a transition tool, but really it can be used for breaking layers into multiple boxes and then have them move in space. -
Joey Foreman
April 26, 2008 at 2:12 amThe blocks aren’t really even coming together – they’re just moving forward in z to about the same point and vanishing. No need to move the camera. No need to create a camera. Just toggle the block layers to 3d and animate their z position, starting with a negative value and going to positive. You’ll need to offset their initial x position as well.
Darby Edelen
April 26, 2008 at 2:30 am[Joey Foreman] “The blocks aren’t really even coming together – they’re just moving forward in z to about the same point and vanishing.”
Ah, I wish it were true, but alas the logo is forming (‘coming together’) from some of those blocks. It’s clear to me that the blocks are animated in more than one dimension. If you look at the face of the logo it takes a much different path to find its resting point than the lower portion of the logo, even though they share a common line in the final logo.
Most of the blocks do keep moving beyond and eventually disappear.
I still think that the best process would be to animate the blocks in one composition, pre-comp it, collapse transformations and then animate a camera as needed.
Darby Edelen
Lead Designer
Left Coast Digital
Santa Cruz, CA -
Joey Foreman
April 26, 2008 at 5:08 amWatched it again and stand corrected.
How about dividing the graphic into a series of layers via masks. Make em 3d. Keyframe their inital position. Move these keyframes down the timeline. Proceed as from above, moving the layers individually back in Z and to the side. Maybe slide them up or over a bit in the middle to make a slight arc. Stagger the layers in time. Nice eases at the end and fade out.
Still don’t need a camera. -
Aaron Keeny
April 29, 2008 at 2:03 pmThanks everyone for the suggestion. I just finished the project and ended up using a combination of camera and moving the blocks in Z space and just nesting different layers/blocks and text into different comps.
Again thanks for the help. Love the cow!!!!
Aaron
Randy Cates
May 12, 2008 at 4:28 pmThis effect is definitely the Card Wipe plugin. Go to https://www.ayatoweb.com/ae_tips_e.html (great resource too btw)and the first QT on example #31 is this effect with a camera angle which you can click on and watch https://www.ayatoweb.com/ae_tips_e/ae31_e.html
download his plug in settings JPG and then you can adjust block size, cam angle, speed etc. to fit your needs.
Randy Cates
Randy Cates
Broadcast Designer/Animator -
Aaron Keeny
May 12, 2008 at 4:33 pmThank you very much. Awesome website I bookmarked it so I am sure I will be visiting there a lot for some reference/advice.
Aaron
Randy Cates
May 12, 2008 at 4:38 pmNP Aaron,
That is an awesome sight. Be aware this guy speaks broken english and his tutorials assume you can figure most of what he’s doing by looking at settings and his general (and I mean general) direction.
Here’s another guy (American) whose GREAT (if you haven’t found him already. Former special effects guy. https://www.videocopilot.net/ go to his tuotrial link lots of cool tutorials with step by step directions.
Lastly, share these links (it’s the right thing to help others – wink). Enjoy
Randy
Randy Cates
Aaron Keeny
May 12, 2008 at 5:36 pmAndrew Kramer. He is great used his website and tutorials more times than I can count. Also purchased a couple of his dvds.
