Activity Forums Panasonic Cameras Any thoughts on BEST way to bulk erase HD tapes when recycling?
  • Any thoughts on BEST way to bulk erase HD tapes when recycling?
    Posted by Marion Laney on November 14, 2005 at 11:14 pm
    We are starting to recycle our camera masters from the beginning of this season of shows. Our understanding is that this tape stock does not easily bulk erase. For ease of editing I would prefer to not have old TC anywhere on the tape.
    One suggested solution is we re-black all the tapes. This is an option but does anyone know what the expected real world life of a 1200a head might be and how much/difficult a replacement will be?
    Any other solution are welcome.
    thanks!
    Marion
    Marion Laney
    Director-DP-sometimes Editor
    ideaWercs, inc.
    Atlanta, Ga. USA
    Producing in HD&35mm&SD
    Food Network series “Good Eats” and others.
    Marion Laney replied 20 years, 10 months ago 2 Members · 2 Replies
  • Steve Mahrer
    November 15, 2005 at 9:17 pm
    Hi Marion:
    DVCPRO tapes are thin film metal particle tapes with VERY high coercivity, about 2200 Oesteds, Betacam by way of example is about only 600 Oe. The higher coercivity makes DVCPRO tapes very hard to erase with conventional bulk erasers…. they may buzz, but the tape may still have signals recorded after “bulking”.
    In reality however, your fears of “old” timecode causng problems are very unlikely as the TC in DVCPRO / DVCPRO HD is recorded in the DIF signal’s subcode area (actually recorded as part of the Video / Audio data). This means the TC can only be read by playing the tape and then demuxing the data to extract the TC. It’s not like 1/2″ formats with a TC edge track. Blacking the tapes beforehand could be done, but it’s a real time operation and costly in terms of both decks and people. You can reuse tapes by simply recordng over them, just ensure that no clients material remains at the tail end!
    Cheers,
    Steve Mahrer (Panasonic)
  • Marion Laney
    November 15, 2005 at 9:58 pm
    Steve,
    Thank you for the clarification. I had been informed with similar info but your concise description of the forces at work are very helpful. Fortunately I will only recycle these on the “Good Eats” series as inhouse backup masters.
    Best regards,
    Marion
    Marion Laney
    ideaWercs, inc.
    Atlanta, Ga. USA
