Activity › Forums › Adobe Premiere Pro › Any suggestions for Cineform AVI w/24bit audio?
  • Any suggestions for Cineform AVI w/24bit audio?
    Posted by Joshua Weiss on January 4, 2010 at 10:39 pm
    I rendered out my uncompressed mov to a cineform avi so my cs4 wouldn’t have to work as hard when using the video file. But unfortunately, I can only do a 16bit cineform avi file. Any suggestions for a high quality alternative. My source video was HD 1920 x 1080p 24fps. I need the output to maintain quality while easing the work of the computer. I have AJA xena Lhi and Cineform Prospect HD. Hopefully this will give you an idea of what various codecs I am able to export.
    Joshua Weiss
    Aristides Tiropolis replied 16 years, 8 months ago 3 Members · 4 Replies
  • Aristides Tiropolis
    January 7, 2010 at 10:49 am
    Is there a problem with exporting a separate 24 bit .wav or aiff file to use in your timeline?
  • Joshua Weiss
    January 7, 2010 at 3:54 pm
    Kind of. The clip is an hour and a half movie that is being cut up and placed in 12 different television episodes. If I have a seperate audio file for the video, then I have to constantly be concerned with it being in good sync. If it was just a solid AVI with audio connected, then I could use the preview monitor to just select the in and out points and not have to worry about a huge timeline or a second timeline that just contained the movie.
    Joshua Weiss
  • Tim Kolb
    January 7, 2010 at 4:13 pm
    What’s in the content that is more sophisticated than 16 bit?
    What was the material recorded on? (acquisition format)
    TimK,
    Director, Consultant
    Kolb Productions,
    January 7, 2010 at 4:29 pm
    Well, after exporting the video and the audio you then select the two tracks and right-click->link the video and audio. It will then be as if you had a unified clip and will mitigate potential syncing issues and hey, it makes audio editing in other applications a much faster process, especially when dealing with AAF sequences…
    Cheers.
