Activity › Forums › Media 100 › Any shortcut to “Select All in Range” across multiple tracks?
  • Any shortcut to “Select All in Range” across multiple tracks?
    Posted by Andrew Mehta on February 26, 2007 at 7:04 am
    Media100i 7.5 (OS9).
    Floh helped out with a shortcut key for moving synced audio between tracks before, so I thought I’d try asking if there’s a time saver for one of my most common tasks atm – and that’s selecting everything in a range, across tracks. Atm, I’m just using the “Select in Range in Track” option from the program menu, and holding in the shift key, and doing it again, times however many tracks there are ( usually one graphic, one video, and eight audio – a total of 10 tracks! ).
    Is there any way to select all in range, without doing it a track at a time?
    Andrew Mehta replied 19 years, 7 months ago 2 Members · 2 Replies
  • Floh Peters
    February 26, 2007 at 7:13 am
    [Ajmetz] “Is there any way to select all in range, without doing it a track at a time?”
    If you press and hold the “ALT” key while being in the Program menu the “Select in Range in Track” changes to “Select in Range”, which allows to do exactly what you want.
  • Andrew Mehta
    February 26, 2007 at 7:24 am
    Wow! O_O…hidden menu items. (What is this? Microsoft Word? Lol)
    ^_^ But it works, so thanks. =)
