Activity Forums Field Production Any recommendations for an SD card reader?
  • Any recommendations for an SD card reader?
    Posted by Noam Osband on June 15, 2011 at 4:12 am
    I have these old card readers that are unreliable and often seem to lose their connection with the computer halfway through a transfer. So, I’m going to buy a new reader. Anyone have a recommendation for one? I use a MacBook Pro if that somehow impacts the answer.
    Bill Davis replied 15 years, 2 months ago 2 Members · 1 Reply
  • Bill Davis
    June 15, 2011 at 6:56 am
    I have two in my kit.
    The “expensive” one is a SanDIsk Imagemate SDDR-92 CF reader. It was probably about $40 bucks.
    The cheap one is a Digital Concepts “6-slots Hi speed 51 in 1 Card reader/writer. It probably cost $8
    Both work just fine via USB.
    I own both because in my experience, it’s pretty easy to bend the delicate pins on a CF card – and the SanDisk unit has a much better engineered card feed slot – so the chance of bending a pin on the CF downloads that I do all the time on my 5d footage rolloffs are easier.
    The cheap one reads virtually ALL card formats. I use it mostly for smaller cards like SD, memory stick, etc – devices that don’t have those hair fine pins.
    I have used the cheap one to read CF data – I’m just VERY careful about seating the cards since I don’t want to screw up the pins.
    My 2 cents.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Conner
