Activity › Forums › Apple Final Cut Pro Legacy › Any recommendations for a “fake” SAN?
  • Any recommendations for a “fake” SAN?
    Posted by Pat Hindman on August 30, 2012 at 3:28 am
    Howdy everyone.
    I’m a small-time freelance editor. I have an iMac and looking to add my Mac Mini to the mix so I can switch over to it while rendering on the iMac, vice versa, etc.
    Any suggestions on an inexpensive way to share a drive(s) with both machines? One of my clients has a nice SAN setup via Fiber but I certainly can’t afford anything like that. I rarely work with footage above 1080p so perhaps a sharable Gigabit Ethernet drive solution would be fast enough? Or maybe there’s a way to share a small server between both via Thunderbolt?
    Since I’m only needing to share the drive between 2 machines next to each other and not several edit stations on a company-wide network, I’m hoping there’s a solution that won’t break the bank.
    Any input is muchos appreciated!
    Jeff Meyer replied 14 years ago 2 Members · 1 Reply
  • Jeff Meyer
    August 30, 2012 at 10:31 pm
    Give AFP file sharing a try. Should take care of your needs. Here’s how to set up the host:
    https://support.apple.com/kb/HT1549?viewlocale=en_US
    Select Get Info for a volume on your desktop to share that entire volume.
    On the other computer open Finder and pick Go -> Connect to Server
    Type in afp://IP address of host computer
    Log in, and pick which shares to mount.
