Activity › Forums › DaVinci Resolve › Any reason NOT to use GTX285s?
Posted by Paul Nordin on January 7, 2011 at 6:45 pmI’m just about to purchase the Cubix box and build a DaVinci resolve system. I could swing a couple of PNY Quadra 4000s, or there still seems to be supply of GTX 285s. I’m hessitant to buy into discontinued equipment, but it seems like the GTX285 saves several hundred dollars/card and gets better performance. I’ll be putting these in the Cubix along with a RedRocket card.
I’m not a hardware geek, so for those of you who are, or for those with more experience with this system,is there any reason I am overlooking that would make going with two Quadro 4000s a better decision?
Thanks for your feedback!
_______________________
El Mundo Bueno Studios
Film * Audio
http://www.EMBstudios.com
Emeryville, CA
_______________________Darin Wooldridge replied 15 years, 8 months ago 8 Members · 10 Replies -
Darin Wooldridge
January 7, 2011 at 9:55 pmPer black magic it seems the GTX285 works best with the Resolve..
One negative, its a double wide card and eats up two slots in many configurations .
The 4000 without the daughter card is only single lane.My second 285 arrived just today. 🙂 Now i just need something to stuff them both in..
NOTE: The comments above are strictly mine, and may not necessarily
represent those of my employers.Darin Wooldridge
Colorist / Technical Strategist
818-653-3918-cell
dwooldridge@mac.com
check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=…. -
Robbie Carman
January 8, 2011 at 12:01 ammy dual 285 setup is rocking my world. If you can find the 285s its well worth the investment.
Robbie Carman
Colorist and Author
Check out my new Books:
Video Made on a Mac
Apple Pro Training Series DVDSP
From Still To Motion -
Illya Laney
January 8, 2011 at 12:20 amWhy did they stop making these for Mac?
twitter.com/illyalaney
Rohit Gupta
January 8, 2011 at 2:28 amGPU Memory – the Q4000 has twice the amount of RAM. This makes a difference when working with 3K/4K files. When using a complex node structure, especially with mattes, you might run out of GPU RAM.
Vladimir Kucherov
January 8, 2011 at 5:10 amI’m guessing NVidia wanted to stop making older GPUs and Apple reached another deal with ATI
Darin Wooldridge
January 8, 2011 at 7:30 amI stand corrected. Per Rohit s last post the 4000 is now the better card for the resolve.
I see the memory bandwidth is:
89.6 GB/s on the 4000
159 GB/s on the 285More cuda cores in the 4000:
256 in the 4000
240 in the 285And as rohit has pointed out double the memory on the 4000.
Rohit will one see a performance gain switching from the 285 to the 4000?
818-653-3918-cell
dwooldridge@mac.com
Paul Nordin
January 8, 2011 at 7:30 amThanks everyone. I went with an ebay seller and bouught a couple of new GTX285s for $430. I’m probalby going to also get a Quadro 4000 for the GUI card so I can get cuda support for adobe.
Is there any penalty for mixing GPU cards? In other words, if I put a GTX 285 and a Quadro 4000 in the Cubix box for GPU, is there some sort of load balancing algorithm that will run less efficiently in Davinci (as opposed to the cards both being the same model)?
Cheers,
Paul_______________________
Film * Audio
Emeryville, CA
_______________________ -
Kevin Cannon
January 8, 2011 at 4:48 pmThe Blackmagic folks hav been saying that mixing cards is not ideal; the load will be balanced evenly across all the GPUs, so faster cards may be handicapped to equal slower cards…
prehistoricdigital.com
hardworkingpixels.com -
Darin Wooldridge
January 8, 2011 at 11:47 pmI believe the 4000 is approved for the gui.
My guess is a pair of 285’s for the gpu and the 4000 for the gui should work very well.Let me know how it works. I may replace my 120 for the 4000.
818-653-3918-cell
dwooldridge@mac.com
