Activity Forums Adobe Premiere Pro Any reason not to encode from the preview file(s)?
  • Any reason not to encode from the preview file(s)?
    Posted by Vjohn on May 29, 2005 at 11:49 pm
    When asked to export/encode PPro ignores any preview files that it may have created, and renders again in the course of encoding. Given that software rendering is awfully time consuming if one has been at all liberal with video effects, is there any reason not to encode from the preview files (assuming one knows that they are current and complete, of course)?
    Vjohn replied 21 years, 3 months ago 3 Members · 4 Replies
  • Steven L. gotz
    May 30, 2005 at 2:31 am
    Yes. There is a reason.
    The material that started out as DV AVI will not be any different, but there are materials, like photographs, that will not look as good if you encode to DV AVI before transcoding to MPEG2.
    Is it important? Not usually. Not for most people. But if you want to avoid that one generation of loss, then encode directly from the timeline using the original material, and not the DV AVI it was encoded to for preview purposes.
    Many people prefer to export a DV AVI and then let Adobe Encore do the transcoding.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Vjohn
    May 30, 2005 at 4:23 am
    Thanks for the insightful reply, Steven.
  • Perry Cheng
    May 30, 2005 at 3:56 pm
    So, is there a way to encode from previews? Import all the previews files and then butt them together? Or? I think for most people, that will be much faster… for a quick project.
    perry
  • Vjohn
    May 30, 2005 at 4:36 pm
    That’s just what I did to experimentally verify the process. It’s a bit of a chore since the program creates a gaggle of preview files, not just one, and I think they need not sum to the work area – if a snippet didn’t need rendering, it’s left out. But given that it’s pretty easy to apply effects that take 5:1 or 10:1 to render, avoiding re-rendering can save a ton of time.
    An interesting workflow might involve incremental export to DV AVI for preview; those files could be brought back into the project on a new track and time-aligned. Clip boundaries would be obvious and clips in the original could be further edited as necessary and then copied over the new working track, or the clip bounds could be duplicated into the working track.
