Activity Forums Adobe Photoshop Any one can help me with resizing selection?
  • Any one can help me with resizing selection?
    Posted by Val Pashchenko on February 8, 2010 at 4:55 pm
    Hello Guys!!
    Any one can help me with resizing selection? , basically I cut one object from one image and drag it in to another one.
    How can I resize only object that I need on my working file? I understand that I will need to select this object? If I am wrong please correct me.
    Thank you !!
    Val Pashchenko
    Scott Roberts replied 16 years, 7 months ago 3 Members · 2 Replies
  • Jack Sewell
    February 8, 2010 at 5:15 pm
    For a Mac, ‘Alt – Command – I’ This will bring up the pixel dimensions which you can then change. Alternatively, once the move tool is selected, you can tick the ‘show transform controls’ box at the top bar, which will then show you a small box in each corner of the object. Hold shift while dragging them in or out to keep proportions the same.
  • Scott Roberts
    February 10, 2010 at 7:22 am
