Activity Forums VEGAS Pro Any news about a VP 22 being released?
  • Any news about a VP 22 being released?
    Posted by Rich Kutnick on July 10, 2024 at 3:31 pm
    As stated a few months ago, my PC has major issues with VP 19 so I have reverted to a fully stable VP 18. I DO want to keep in the upgrade loop and want to know if anyone has heard about a VP 22 app, which if as Magix has done for a number of years would start distributing the upgrade next month. I also have found that I have the need for VST-3 integration, which I believe VP 21 contains. Would it be advisable to perhaps upgrade to VP 21 right now, then again upgrade if and when VP 22 becomes available? Does anyone know if I do this if VP 22 would be offered free to me if I just recently upgraded to VP 21? Thanks in advance!
    Steve Rhoden replied 2 years, 2 months ago 3 Members · 5 Replies
  • Hector Vera
    July 10, 2024 at 5:45 pm
    Yeah it seems via their main website at vegascreativesoftware, there is a 2 for 1 deal where you can get Vegas 21 for free if you pre-order VEGAS Pro 22 so you can get 21 right away. And here is the link if you want to know more about it: https://www.vegascreativesoftware.com/us/vegas-pro/
    It says it will be released on Summer 2024 so I would assume it should be out anywhere between this month in July till as late as early September cause the Summer lasts until Sept 22nd, 2024. Hope it helps!
  • Rich Kutnick
    July 10, 2024 at 6:22 pm
    Thanks SO MUCH, Hector, not only for the quick reply but also providing the answer for which I was hoping!!!
  • Steve Rhoden
    July 13, 2024 at 12:39 pm
    It will be released within a month or two from this date….
  • Rich Kutnick
    July 13, 2024 at 1:44 pm
    I purchased the update! Now working in VP 21 and looking forward to VP 22!! The AI voice-to-text editing is really cool! Still having ocassional hiccups with “An error occurred during while processing the undo buffer. You should save your work immediately using a new project filename and restart Vegas Pro. The reason for the error could not be determined”. I believe this is caused by New Blue Titler Pro (currently using V 7). Anyone else experience this in any version of VP?
  • Steve Rhoden
    July 13, 2024 at 1:52 pm
    Yeah, Newblue Titler Pro do have some issue with Vegas, because of this i personally don’t use it. But before we blame Newblue, what you can do is uninstall and completely remove it, and then see if this warning still pops up.
