Activity Forums VEGAS Pro Any magic trick for syncing sound and vision
  • Any magic trick for syncing sound and vision
    Posted by Peter Derek on February 15, 2014 at 2:52 pm
    A colleague overseas says he uses one editing app that has a one button feature to sync video with external sound (in his case sound recorded on an iPhone and lavalier) with video
    I use the probably old fashioned method of clapping my hands in shot and syncing the spike in sound to the video
    Anyone got better ways?
    Am I missing a trick here?
    Will Vegas one day offer this feature?
    Kelly Griffin replied 12 years, 6 months ago 4 Members · 5 Replies
  • Roger Bansemer
    February 15, 2014 at 3:29 pm
    The best app to use for syncing multiple audio/video tracks is “Pluraleyes”
    It listens to the audio on each of your clips and matches them up. It works great.
    Roger Bansemer – PaintingAndTravel.com
  • Angelo Mike
    February 15, 2014 at 4:06 pm
    Pluraleyes is the standard for most people. I use it and it’s very effective. But alternative is to slate it as you say and synch up the wave forms (I usually try to get audio in camera as well so I can refer to it).
  • Roger Bansemer
    February 15, 2014 at 4:44 pm
    One thing to remember if you create a slate slap…
    Making the slap too loud can create a portion of your audio louder than anything else which might make the rest of the audio waveform quite low depending on how you have your audio set up with to begin with.
  • Peter Derek
    February 15, 2014 at 5:03 pm
    Thank you both very much for your replies and most valuable recommendation The product appears superb
  • Kelly Griffin
    February 15, 2014 at 9:44 pm
    What I’ve been doing is to just drag the good audio file onto the timeline below the camera audio, just roughly aligning the waveforms of the two. Then, I select the good audio, press “play” and then just nudge the audio left or right (1 or 3) until the echo goes away.
    Pretty quick.
    –KG
